• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Orbitron
    Trouble with Adaptive Part
    207 Views, 4 Replies
    12-17-2012 08:18 AM
    Did a quick search, but did not find anything particularly useful.  Using Inventor 2013.
    I wanted to make an adaptive representation of an extension spring.  I made the "coil" of the spring using a symmetrical extrusion.  I made the extrusion "adaptive" thinking the extrusion length would then adapt as required.  I created the "loops" using sweeps attached to the ends of the extrusions.  I made no longitudinal constraints/dimensions to the origin, although I do have one radial dimension to the origin.  Otherwise, both loops are constrained/dimensioned to the ends of the extrusion.
    I inserted the part into my assembly and set it as "adaptive".  I contrained one end.  I tried to constrain the other end, but the part would not adapt, so it pulled my assembly out of alignment and caused a conflict with another constraint.
    What have I done wrong, or is this not possible?  Thanks
    Please use plain text.
    Re: Trouble with Adaptive Part
    12-17-2012 09:20 AM in reply to: Orbitron
    Orbitron wrote:
    1. ....I made the extrusion "adaptive"
    2.  ....I inserted the part into my assembly and set it as "adaptive".
    Of course it is possible, but must be done correctly.
    1. this doesn't make sense - adaptivity is a result of creating within assembly from projected references.
    2. see #1
    I prefer to Animate a Parameter in Inventor Studio rather than use Adaptivity.
    This topic has been covered here many many times in the past.
    Attach simple assembly and someone will show you both techniques (adaptive and driven parameter) for a spring.
    Orbitron
    12-19-2012 12:44 PM in reply to: JDMather
    Thank you, but that is not what the HELP text and videos suggest, which is what I was trying to follow.
    Is it possible for you to provide a link to one of the more useful examples of previous discussions?  I simply do not have the luxury of spending time reading through hundreds of not-so-useful postings.  Thanks.
    blair
    12-19-2012 12:57 PM in reply to: Orbitron
    Try here, it only takes about 30 seconds to do the seach on YouTube: for the text string: autodesk inventor adaptive
    http://www.youtube.com/watch?v=TaKX68LjhUo
    Do you realize, the majority of the people that are answering the questions to posts such as this are doing it on a volunteer basis out of the kindness of their hart.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    12-19-2012 02:32 PM in reply to: Orbitron
    Attach your assembly here.
    When referencing Help information or other sources of information be sure to provide the direct url.
