Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Trouble with Adaptive Part
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did a quick search, but did not find anything particularly useful. Using Inventor 2013.
I wanted to make an adaptive representation of an extension spring. I made the "coil" of the spring using a symmetrical extrusion. I made the extrusion "adaptive" thinking the extrusion length would then adapt as required. I created the "loops" using sweeps attached to the ends of the extrusions. I made no longitudinal constraints/dimensions to the origin, although I do have one radial dimension to the origin. Otherwise, both loops are constrained/dimensioned to the ends of the extrusion.
I inserted the part into my assembly and set it as "adaptive". I contrained one end. I tried to constrain the other end, but the part would not adapt, so it pulled my assembly out of alignment and caused a conflict with another constraint.
What have I done wrong, or is this not possible? Thanks
Re: Trouble with Adaptive Part
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Orbitron wrote:1. ....I made the extrusion "adaptive"
2. ....I inserted the part into my assembly and set it as "adaptive".
Of course it is possible, but must be done correctly.
1. this doesn't make sense - adaptivity is a result of creating within assembly from projected references.
2. see #1
I prefer to Animate a Parameter in Inventor Studio rather than use Adaptivity.
This topic has been covered here many many times in the past.
Attach simple assembly and someone will show you both techniques (adaptive and driven parameter) for a spring.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you, but that is not what the HELP text and videos suggest, which is what I was trying to follow.
Is it possible for you to provide a link to one of the more useful examples of previous discussions? I simply do not have the luxury of spending time reading through hundreds of not-so-useful postings. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Try here, it only takes about 30 seconds to do the seach on YouTube: for the text string: autodesk inventor adaptive
http://www.youtube.com/watch?v=TaKX68LjhUo
Do you realize, the majority of the people that are answering the questions to posts such as this are doing it on a volunteer basis out of the kindness of their hart.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 320.18
SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attach your assembly here.
When referencing Help information or other sources of information be sure to provide the direct url.
