Autodesk Inventor
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Translatio nal/Rotati onal constrain for pin in slot.
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
655 Views, 17 Replies
08-15-2008 10:34 AM
How do you constrain a pin so that it can translate/rotate within the boundaries of a slot? Please see the attached pic's.
Jason
Jason
Re: Translatio nal/Rotati onal constrain for pin in slot.
Options
- Highlight
- Email to a Friend
08-15-2008 10:42 AM in reply to:
Jason.Taylor
Transistional - not rotate/translate
Pick the side of the pin and the slot. I can never remember which order so try both ways.
Can you zip and attach what you have so far?
Options
- Highlight
- Email to a Friend
08-15-2008 10:45 AM in reply to:
Jason.Taylor
create transitional constraint.
Pick the cylindrical surface of your pin first then the flat face of the slot (on the inside of the slot).
Please click "Accept as Solution" if this response answers your question.
2012 Product Design Suite Ultimate
Windows 7 64 bit
90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
Windows 7 64 bit
Options
- Highlight
- Email to a Friend
08-15-2008 11:10 AM in reply to:
Jason.Taylor
I am trying to constrain the bolt so that it can translate / rotate around the inside perimeter of the slot. However, when I use the constraint "translate", I can only pick one surface to constrain the outside of the bolt to; not the entire inside perimeter which constricts the movement of the door that this retainer is attached to. I need to figure out how to constrain it to more than one surface (if possible). If not, any ideas are greatly appreciated!
Options
- Highlight
- Email to a Friend
08-15-2008 11:33 AM in reply to:
Jason.Taylor
Somehow inventor automatically knows about the radius portion of the slot and you only need to pick the flat face.
Did you try it as we said..it works just fine picking only the flat
(and you forgot to include the pin in your last zip file) Message was edited by: mcgyvr
Windows 7 64 bit
Windows 7 64 bit
Options
- Highlight
- Email to a Friend
08-15-2008 11:36 AM in reply to:
Jason.Taylor
Delete the tangent constraint.
Also I noticed none of your initial part sketches are constrained - you might want to read this document.
http://home.pct.edu/~jmather/AU2007/MA105-1L%20Mat her.pdf
Options
- Highlight
- Email to a Friend
08-15-2008 11:38 AM in reply to:
Jason.Taylor
Yes, I tried to use the translation constraint picking the pin first and then a surface; however, when I attempt to "open the door" the constraints will not allow me to open it a full 90 degrees. The pin seems to get stuck in the corner of the slot.
Options
- Highlight
- Email to a Friend
08-15-2008 11:40 AM in reply to:
Jason.Taylor
I don't see a door. You will need to supply more parts.
Options
- Highlight
- Email to a Friend
08-15-2008 11:46 AM in reply to:
Jason.Taylor
I believe you are over constraining something
See the attached sample. Its as simple as that
(done in INV2009 so I hope you can open it)
Windows 7 64 bit
Windows 7 64 bit
Options
- Highlight
- Email to a Friend
08-15-2008 11:54 AM in reply to:
Jason.Taylor
Can't open it. I am using INV 08'. I don't think that I have over constrained the model since the door opens when I use a tangent constraint. The only problem is that the pin doesn't stay within the perimeter of the slot.
