• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Re: Translational/Rotational constrain for pin in slot.
    08-15-2008 12:03 PM in reply to: Jason.Taylor
    > I don't think that I have over constrained the model
    It is over constrained - delete the tangent constraint as instructed.
    >The only problem is that the pin doesn't stay within the perimeter of the slot.
    If you drive constraint it should stay within the slot. If you try to drag with the mouse Inventor cannot keep up with the calculations.
    >Can't open it. I am using INV 08'.
    Always state what release you are using when not using the latest release.
    Inventor Professional 2014 Edu 64-bit
    Please use plain text.
    08-15-2008 12:32 PM in reply to: Jason.Taylor
    Put a driven constraint on the door angle and use that to move it not the mouse as JD suggested.
    I've attached an image showing all that is required for the trans constraint
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Active Member
    08-15-2008 01:45 PM in reply to: Jason.Taylor
    WOW... Sorry to waiste everyone's time! I pulled the parts out of my top level assembly and assembled a smaller version (file size) of the enclosure and it worked perfectly (as long as I used one of the arms on the door retainer to adjust the door level)! I guess my rig isn't strong enough to handle the detail that i have on the top level assembly. Sad that it took me half a day to figure that one out!
    Thanks for your help fellas!
    08-15-2008 02:16 PM in reply to: Jason.Taylor
    Assuming you will place that hinge assembly as two instance of a sub-assembly make sure you right click on the sub and set it to Flexible.
    Active Member
    08-15-2008 02:21 PM in reply to: Jason.Taylor
    That is news to me! Thanks for the tip! I actually inserted each piece seperately because I didn't know the function "flexible". I will use that one in the future!
    Thanks again,
    08-15-2008 02:32 PM in reply to: Jason.Taylor
    You can Ctrl right click on the parts and Demote to a sub-assembly. Might speed things up.
    Active Member
    08-15-2008 02:51 PM in reply to: Jason.Taylor
    I tried that but the assembly with the pin and slot didn't "move" or rotate appropriately. I used the Flexible function. What gives?
    New Member
    02-08-2013 09:36 AM in reply to: Jason.Taylor
    Had same problem. Don't know a lot about inventor just getting used to it.  But if you re-extrude your slot holes again with a surface instead of solid, that worked.  The surface button is in the lower left of the extrude pop up box.  It looks lik a hollow box and when you hover over it it says surface. Good luck.
