• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Total weight of a part list
    167 Views, 3 Replies
    11-22-2012 08:32 AM
    i know that this topic could be a old one, but i've been unable to find a proper answer.
    i have an already edited part list (because there are parts that come from different assemblies and other ones that don't have to appear in that part list) and i like to show the total weight of my drawing, that doesn't correspond with any assembly.
    So, there is any possibility of summing up the values of a part list column.
    Thanks in advance
    Please use plain text.
    blair
    Re: Total weight of a part list
    11-22-2012 08:39 AM in reply to: chorch123
    No, since you are already using an "edited" parts list that bears no resemblance to any model, you might as well just import/link an Excel spread sheet that you can at least use the SUM function as well as produce the extended line weights.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 320.18
    SpacePilot Pro 3.16.3 / 6.16.1 / 4.11
    11-22-2012 11:49 PM in reply to: blair
    Thank you very much.
    I'll probably use an excel sheet.
    Is there any way to automatically have associated an excel sheet with the part list?
    Valued Contributor
    11-23-2012 01:31 AM in reply to: chorch123
    Better is, if possible, edit BOM in assembly, use virtual components, or edit quantity directly in model BOM. Then the calcalted weight in drawing will be OK.
