• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    To scribe lines on a cylinder
    315 Views, 2 Replies
    03-01-2012 04:49 PM
    1. I would like to scribe number of lines in axial direction & around the circumference of a cylinder
    2. Secondly, I want those lines to be visible on .idw file so that I can print my drawing
    Sample image attached.
    Thanks.
    Please use plain text.
    Active Contributor
    Re: To scribe lines on a cylinder
    03-01-2012 06:40 PM in reply to: vijay2knight
    just extrude a small cut and array it around the centerline, then revolve a small cut and array it along the length
    M6400, FX3700M, 12GB, SSD
    Win 7 64
    Inventor 2013
    Active Contributor
    03-02-2012 05:16 AM in reply to: vijay2knight
    To get accurate lines on a drawing view, that are controlled within an ipt, you need to use surface modeling.  You project surfaces to the cylinders body, which are created on workplanes that you can move or control.  I attached a screen capture of the idw model tree.  In the idw, you need to right click the ipt and select include all surfaces and on 3D scketches right click and select include.
    Hope this helps.
    Stephen R.
