• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Titleblock Assistance Needed
    140 Views, 5 Replies
    01-22-2013 02:21 PM
    When I make changes to the titleblock, I save them and will be able to see it under the Drawing Resources-TitleBlock box..  Then when I save and close that drawing, open a new drawing to start for another part, it will not show up in the list.. I have done exactly what several insructional videos have said with no luck
    I am new to Inventor, coming from Pro-E... Sorry if this is a simple question
    Please use plain text.
    Distinguished Mentor
    Re: Titleblock Assistance Needed
    01-22-2013 02:53 PM in reply to: chance1080p
    You need to save the changes in your template file. Probably "?:\Users\Public\Public Documents\Autodesk\Inventor20??\Templates"
    rhasell
    01-22-2013 03:16 PM in reply to: chance1080p
    Hi
    You can also do a "Save as", "Save copy as Template"
    The template is similar to PRO-E's start part. (Really going back a few years now, so can't remember so well)
    TIPS:
    Imbed your images if you export your files to AutoCAD
    Keep it "Light" lots of different titleblocks and images in the same template can make the drawing files HUGE right from the get go.
    Reg
    Autodesk Product Design Suite Premium 2014 Build 170
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home) - 12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Active Member
    01-23-2013 05:18 AM in reply to: rhasell
    I should have said that we tried the "save as" also. with the same results
    01-23-2013 05:26 AM in reply to: chance1080p
    Open the file with the title block you want then open the template.  Copy the title block and paste it into the template.
    Are you working locally or are your templates on a network?  If they are on a network, make sure you use the template file on the network, not the local one.
    John Retzlaff
    Active Contributor
    Leander.van.Gorsel
    01-24-2013 04:20 AM in reply to: chance1080p
    The titleblock isn't saved in your template file. Please open the Projects window (on the 'get started' tab), look in your folder options to locate the directery where your template files are in.
    Then press open file, go to this directory, open your drawing template, ignore the warning of opening a file out of your working folder, and then you can change or copy your titleblocks.
    Good luck!
    Projcet file settings
    Green check.png  Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful
    Software: Inventor Series 2013 SP1.1 x64
    OS: Windows 7 Professional x64
    CPU: i7-975X // RAM: 12Gb
    VGA: GeForce GTX 280M
