• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    brandonherrer14
    Accepted Solution
    Title Block Question
    153 Views, 2 Replies
    06-06-2012 03:26 PM
    Dear Forum,
    Really quick question...
    When i make a drawing in inventor, in the Title Block, it says the title of the saved document in the Drawing No. section. So what i am saying is how do i get the title of the saved document out of the drawing number section and either delete it or get it in the Title section.
    Thank You,
    Brandon
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Title Block Question
    06-06-2012 03:36 PM in reply to: brandonherrer14
    Hi brandonherrer14,
    It depends on how your title block is set up, but if you right-click on the top node in the browser of your drawing and choose iProperties, you can look on the Project tab for the Part Number field. If you see the offending text there, then just delete it and all should be well.
    But if it's not there then you will want to open the model and right-click on the top node in the browser and choose iProperties. Then look on the Project tab for the Part Number field and remove remove/change the part number as needed.
    Basically your title block reads information form the iProperties of either the drawing itself or the model that you place in the drawing.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Contributor
    brandonherrer14
    06-06-2012 05:43 PM in reply to: Curtis_Waguespack
    Your great. Thank you for all your help.
    Best of Luck,
    Brandon
