• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Title Block Image Check-In Problem
    80 Views, 2 Replies
    12-21-2012 08:42 AM
    Before we even installed vault, I had created a title block that included an image found in my personal "My Documents" folder. Upon moving to vault and moving all templates to a central location (pointed to by the project file), now I have a problem with that image/logo. I deleted the image and reinserted it from my workspace and UNCHECKED the "link" option, but for some reason, when I try to check in a drawing, I still get the error saying <path to My Documents" isn't in the project or search paths etc. I want to break ALL ties to "My Documents" and I thought I had. How do I go about finding out what my links are and deleting this link?
    Please use plain text.
    Valued Contributor
    Re: Title Block Image Check-In Problem
    12-21-2012 09:21 AM in reply to: drguitarum2005
    Finally found a website that helped me with this particular one. I opened the .dwg template in Autocad and ran Xref and deleted that phantom reference.
    http://www.microconcepts.co.uk/members/tips__tricks/inventor/?artid=1344&pageNum=0&blk=178&artitle=R...
    For anyone interested. Thanks!
    *Expert Elite*
    Curtis_Waguespack
    12-21-2012 10:05 AM in reply to: drguitarum2005
    Hi drguitarum2005,
    I didn't test for this specific case, but I think you can also go to the Tools tab and choose the Links button to do this as shown here:
    http://beinginventive.typepad.com/being-inventive/2011/11/manage-links-command-in-inventor-2010.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
