• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    jarek.pski
    Accepted Solution
    Thread.xls problem
    1037 Views, 2 Replies
    09-05-2010 11:07 AM
    Im running Inventor 2011 32-bit, and have a problem with bolted connection on parts Im trying to assemble.
    All that happens is when I click bolted connection a window pops up that says "Invalid thread data table. Please check Thread.xls" I have physically looked for the Excel file and it's there, with what seems to me a complete thread parameters.
    I have checked the tool>application options and the root files are ok.
    I have recently updated the software to a service pack 1. I have ran out of options and things to check.
    Can anyone help?
    Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz
    4.00GB RAM
    32-bit Operating System (Windows 7 Enterprise)
    NVIDIA Quadro FX 570 (Driver Version: 8.15.11.8593)
    Dual 17'' LCD Screens
    AutoDesk Inventor Professional 2010 (Student)
    32-bit Edition - 2.00GB
    Valued Mentor
    Re: Thread.xls problem
    09-06-2010 11:30 PM in reply to: jarek.pski
    Hello ,
    Maybe your xls file is corupted in some way. Do you have another Inventor in your office that works without problems with the threads. If yes then copy from that pc the xls file and paste it into yours and overwrite. I have attached my xls for you to check if it solves the problem.Overwrite the files when inventor is closed and do a backup on the old one.
    Dan
    Valued Mentor
    09-06-2010 11:39 PM in reply to: jarek.pski
    if the first solution doesnt work try the one in the attachment. Invnetor is version15 now and dont forget to do backup while edting the registry
    Dan
