• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Thicken/Offset and select all faces
    369 Views, 4 Replies
    02-08-2012 11:08 AM
    Hello Inventor Gurus,
    How can I thicken/offset an entire part without having to select all the faces individually?  The 'chain select' option is not good enough for selecting all faces/surfaces that meet and form an edge with no fillet.
    Is there still no way of doing this in 2012?
    Cheers,
    Jay
    Please use plain text.
    Re: Thicken/Offset and select all faces
    02-08-2012 11:18 AM in reply to: jay.davey
    Can you post your part?
    Active Member
    02-08-2012 11:39 AM in reply to: jay.davey
    Here is an example part.
    Cheers,
    Jay
    02-08-2012 12:12 PM in reply to: jay.davey
    A little less work than selecting all the faces.
    No selection for shell outward.
    Delete a couple of faces.
    Patch outer face.
    Sculpt.
    Active Member
    02-08-2012 12:29 PM in reply to: JDMather
    Works good enough for what I need.  Thank you.
