• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    The Selected component has no volume
    267 Views, 2 Replies
    11-21-2012 11:01 PM
    I tried to import an stl file into inventor 2013 and it worked. I now have that ipt file that I ahve attached to this thread. The only problem is that now I cannot manipulate my solid (i.e. put holes in it).
    Has anyone run accross this problem or have any idea what needs to be done?
    Khash
    Please use plain text.
    Employee
    Re: The Selected component has no volume
    11-22-2012 03:57 AM in reply to: knattagh
    Hi Khash,
    Thanks for your post - you won't be able to perform those solid operations since the .stl is a mesh.
    There's a plug-in on the Labs site (link below) that will allow you to convert this to a Base feature, if you install that then you should be good to go :smileyhappy:
    Hope this helps!
    Indy
    http://labs.autodesk.com/utilities/inventor_mesh/
    ConvertToBase
    Inderjeet Wilkhu
    SQA Engineer
    Autodesk ShapeManager
    Design, Lifecycle and Simulation
    Employee
    11-23-2012 01:04 AM in reply to: wilkhui
    Hi Khash,
    Just add one comment, not only STL mesh but also for CATIA V5 cgr mesh data and JT mesh data, this addin (Inventor Mesh Enabler) tool can also convert mesh data to solid or composite.
    Kevin Li
    Quality Assurance Team
