• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    mrattray
    Thank you AutoDesk.
    500 Views, 19 Replies
    05-03-2012 12:24 PM
    Thank you for creating a superior product that knows when I don't really want that last 10 minutes of work I just did.
    Mike (not Matt) Rattray
    Please use plain text.
    GSE_Dan_A
    Re: Thank you AutoDesk.
    05-03-2012 12:41 PM in reply to: mrattray
    Was singing that exact tune yesterday except replace 10 minutes with 15 minutes :smileyvery-happy:
    GSE Consultants Inc.
    Windsor, ON. Canada
    Valued Mentor
    CelticDesignServices
    05-03-2012 01:05 PM in reply to: mrattray
    Now wait just one cotton-pickin' minute.....we all signed that legal and binding contract when using this software where the catch-all, save their arse phrase of "save often" is listed.
    Now in the theme of President Clinton, it depends on what the definition of "often" is.
    Obviously it's under 10 minutes in this case.
    Jim
    Celtic Design Services, LLC
    Inventor/AutoCAD/Vault WorkGroups
    Always for hire - celticdesign01ATyahooDOTcom
    http://www.linkedin.com/pub/celticdesignservices-llc/51/610/398/
    Please use the Accept as Solution and Give Kudos functions as appropriate to further enhance the value of these forums.
    Go raibh maith agat (in other words...Thank you!)
    rhasell
    05-03-2012 04:23 PM in reply to: CelticDesignServices
    We have all learn't the lesson the hard way, save, save, save.. often. Doing so reduces hangs to almost zero. :smileywink:
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Valued Mentor
    Rich.O.3d
    05-03-2012 08:42 PM in reply to: rhasell
    Thats all well and good for what i call a 'hard' crash.
    But i sometimes get what i call a 'soft' crash.
    Sometimes inventor 'crashes' in the background and lets you keep working away non the wiser.
    Then when you reopen...the last hour of saves did nothing.
    Used to happen a fair bit back on 2009/2010 but not so often on 2011 and less on 2012
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Active Member
    Jason.Amess
    05-04-2012 06:33 AM in reply to: Rich.O.3d
    I think you'll find that Inventor was so impressed with your desktop picture that it decided you needed another look.... immediately.
    Jas
    GSE_Dan_A
    05-04-2012 08:13 AM in reply to: Jason.Amess
    My personal fav. is when this scenerio happens...
    "OK Im just going to extrude this last sketch and then I will save.... "(Extrude Performed), (White Snowy Background Appears), (Blue Ring of Death Appears) CRASH.
    Windsor, ON. Canada
    mrattray
    05-04-2012 08:21 AM in reply to: GSE_Dan_A
    That's exactly what happened in that photo, except I was just going to deselect that punch center and then save. Of course if it wasn't for IV's random mid-save lunch breaks I wouldn't put off saving. The truly worst part was that I had fixed some faulty geometry right before this and it must have taken me half the morning just to remember what I had done to fix it.
    I don't like to make posts like this but I needed to vent and everyone in my office had gone home for the day. This was all I could do to keep my fist out of the monitor.
    cbenner
    05-04-2012 08:59 AM in reply to: mrattray
    Do you check your processes before forcing Inventor to shut down?  Sometimes what appears to be "Not Responding" and the infamous rolling donut of death... is just a slowdown.  Lots of times it WILL come back if you give it long enough.  Sometimes... not so much.
    But... I have to say... Pro E was the worst I've worked with for CTD with no warning whatsoever.
    ChrisB
    Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
    Distinguished Contributor
    Mason-Paul
    05-04-2012 09:12 AM in reply to: mrattray
    What is even more annoying is when Autodesk LOWER END software, NO I'm not knocking or anything like that, AutoCAD has a setting for automatic timed saves with out user interaction.
    So the question should be "AUTODESK WHY CAN'T THIS AUTOMATIC SAVE BE INCORPORATED INTO INVENTOR SOONER RATHER THAN LATER??"
    May be we should start a petition for this to be included in the next release or two
    Thanks in advance for any help & advice
    Inventor 2012 Pro
    Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
