• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Mentor
    cbenner
    Texture Purge
    354 Views, 4 Replies
    01-14-2011 04:46 AM
    Help!  I was messing around with style editing, and added a texture map to a style as a bump.  The bitmap I selected, however, was on my hard drive, not in the project search path.  Now that I would like to check this part into the vault, I get the attached error message.  I have since tried deleting, copying, moving the file from that hard drive to a legitimate search library.... removed it from every style it was used in, purged all styles, basically deleted it from every place I can find it, including going through the model tree and checking each individual feature (over 50!) to try to find it.  It is still in the file somewhere, and I can't seem to figure out where.  Is there no way to find and purge this offending bitmap?
    Please click "Accept as Solution" if this response answers your question.
    ChrisB
    "Alcohol never solved anyone's problems,... but then again niether did milk."
    Valued Mentor
    Re: Texture Purge
    01-24-2011 04:36 PM in reply to: cbenner
    I have the exact same problem with some of my IDW files.  In my case I think there is some problem with my xml files though.  I never found a way to purge the offending file from my idw as there are cases of this happening with macros written to solve the problem but these did not work for me either in these cases.
    If you simply want to vault it, create a text file with the exact same name as the bitmap and place that file in the same folder as your file.  Close Inventor and start inventor again.  When you open your file, hopefully it will see your "bitmap" and allow you to vault.  This solution worked for me although it was still a pain to be vaulting a text file that does not do anything.
    Rob
    cbenner
    Re: Texture Purge
    02-14-2011 08:29 AM in reply to: RobJV
    Rob,... I finally got back to this project and tried your solution.  It worked.  I now have this random file in the vault, but at least I can check in the model I was having trouble with. Thank you!!
    ChrisB
    PC2011
    Re: Texture Purge
    02-14-2011 09:56 AM in reply to: cbenner
    Hello
    If you go to tools tab select >links then you can break link
    Re: Texture Purge
    02-09-2012 03:28 AM in reply to: PC2011
    PC2011 wrote:
    Hello
    Yup this is what I have done in the past. There is a bug with Inventor creating links for textures residing in project library paths. It doesn't do this if the texture/image file is in the default Application library... I detailed this heavily on a thread in this forum. Its late here now and can't be bothered to look for it to post the link. But feel free to look for yourself ;-)
    Product Design Suite Premium 2012 64bit - Vault Professional 2012
    Workstation: Gigabyte X58-UD3R Motherboard - Intel i7 930 @ 2.80GHz - EVGA Nvidia GeForce GTX 470 -
    12GB DDR3 1333MHz - 160GB Intel G2 SSD - Win7 Pro 64bit
    Vault Server: 2 x Intel Xeon 3.2 Gig Hex core - 4 x 4GB DDR3 RAM
    2 x 2TB Samsung spinpoint HDD's RAID 0 Boot drive - 6 x 2TB Samsung spinpoint HDD's RAID 10 Database store
    Windows Server 2008 R2 - SQL Server 2008 Standard R2
