• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Anthony
    Accepted Solution
    Text alignment will not change
    136 Views, 3 Replies
    01-10-2013 03:29 AM
    I cannot change the leader text position to be aligned next to the leader line, the text is positioned offset from the line, how do I correct this please ? See attached image
    Please use plain text.
    *Expert Elite*
    sam_m
    Re: Text alignment will not change
    01-10-2013 04:18 AM in reply to: Anthony
    double click on the leader to bring up the text box and then click the middle button in the vertical alignment to make it in-line with the leader.
     *edit* - also check you don't have a line-break/enter after your text, which can make it "float" higher than desired at times.
    Please mark this response as "Accept as Solution" if it answers your question - but note that the solution may not be the answer you're wanting to hear...
    Lithium - helping nntp users with mania, depression and headaches
    Anthony
    01-10-2013 04:24 AM in reply to: sam_m
    Hi, thanks for you reply, my text editor does not appear to have this option in it, not sure why this is, I have tried changing this in the styles editor but it will not change the text alignemnt.
    Anthony
    01-15-2013 05:58 AM in reply to: Anthony
    I have now fixed this error, I had ESKD support add-in loaded into my IV environment which was restricting the options available under the text editor. I have now changed it load behavior and the annotation editor is working fine.
