• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Cadmanto
    Text Notes in Drawing Views
    198 Views, 9 Replies
    01-03-2012 11:23 AM
    Is there a way to associate a text string to a drawing view so when the view is moved
    around the text goes with it and remains placed in accordance with the view?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Please use plain text.
    Curtis_Waguespack
    Re: Text Notes in Drawing Views
    01-03-2012 11:27 AM in reply to: Cadmanto
    Hi Cadmanto,
    Here's a tip on this:
    http://inventortrenches.blogspot.com/2011/04/associate-text-note-with-drawing-view.html
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Cadmanto
    01-03-2012 11:34 AM in reply to: Curtis_Waguespack
    Curtis,
    That is a great reference and I appreciate it, but the note I have that I want associated
    is not linked to a custom property or needs to be.  It is just a label note.
    In Solidworks as long as the view is highlighted if you add a text note it will automatically link
    to the view.
    Best Regards,
    Scott McFadden
    01-03-2012 11:42 AM in reply to: Cadmanto
    The tip from Curtis doesn't have to be a custom property.. It works the same with a regular "label note" as you call it. He just shows how to do it with properties too.
    You can also do it by selecting a view and starting a sketch and placing the label note text in the sketch.. (but the leader method is faster)
    Please click "Accept as Solution" if this response answers your question.
    2012 Product Design Suite Ultimate
    Windows 7 64 bit
    90G OCZ SATA 3 SSD (My SSD is faster than your HDD)
    Core I7 920 processor, ATI HD6970 graphics card, 12G Corsair RAM
    Curtis_Waguespack
    Hi Cadmanto,
    It's been a while since I've used Solidworks, but it sounds like this is easier to do in that program. In Inventor using the leader trick is the best way to create text associative to the view. Note that if it's just a static text note, you can just type it into the text box and then hide the leader, as described in the link.
    The other way to do this is to select the view, and then create a sketch, and then create the text as part of the sketch. but I think this adds a "layer" that is not needed for simple text.
    FYI: You can go to this link and request that the Inventor developers improve this if you'd like:
    http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    I hope this helps.
    Curtis
    Distinguished Mentor
    ampster
    01-03-2012 11:43 AM in reply to: Cadmanto
    same thing applies to plain text, just delete the leader afterwards.
    HTH
    ugh, in the amount of time it took to look over the link and make my reply, a couple of people stated the same thing.
    Cadmanto
    01-03-2012 12:50 PM in reply to: Curtis_Waguespack
    Thanks Curtis for the link.  I am sure that I will be having plenty of suggestions.
    It is hard being very prolific in one software (i.e. Solidworks) and then switching to another.
    But I am getting there.
    I tried creating the text as part of the sketch and it still didn't link to the view.  Any chance you can post
    a sample part/drawing file for me to evaluate?
    Appreciate it.
    Scott
    Best Regards,
    Scott McFadden
    Cadmanto
    01-03-2012 12:51 PM in reply to: mcgyvr
    Thanks.  I am just going to have to keep working at this.  Haven't gotten it to work as of yet.
    Scott
    Best Regards,
    Scott McFadden
    01-03-2012 01:06 PM in reply to: Cadmanto
    Scott,
    place your views in the drawing then click on the view you want your text associated to (a dotted rectangle should show up around the view) then press the "s" key. That will start the sketch being linked to that view.
    Windows 7 64 bit
    Cadmanto
    02-07-2012 10:13 AM in reply to: mcgyvr
    Thank you.  That worked like a charm!!!
    Best Regards,
    Scott McFadden
