Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Text Box
- Highlight
- Email to a Friend
Please excuse if thsi question is simple and has been covered already in this forum. Ive searched.
What i want to do is put an outlining box around some text on my .idw. so it stands out among other text's
Re: Text Box
- Highlight
- Email to a Friend
killall-9 wrote:Please excuse if thsi question is simple and has been covered already in this forum. Ive searched.
There's two ways about going about having an outlining box around text. The simplest way is to start the text command and begin typing. After finishing the text command, begin the sketch command. Then draw your box around the text you've just completed. This will work just fine if you don't need to move the text. Since the box sketch is independent of both the text and other objects on your drawing sheet, you must pick both items first before moving the text with the box.
A more elegant solutions would be to make the box dependent of the text position. In other words you may select either the box or the text and both will move simultaneously.
In order to make the position of the box dependent of the text position you need to do the following:
Complete typing the message you wish to have enclosed in the box. BEFORE using the sketch command, select the text. Then carefully draw and position the box around the text. Season to taste. Now, finish the sketch command. Your text and box will move in tandem.
If you want the test and the box to be dependent to a particular view, be sure to pick the view first, before starting the sketch command.
The sketch command can be accessed via the short-cut key "S". Or you may use the sketch icon located just right of center on the ribbon while using the annotation tab.
Hope this helps!
Please use the accept button if this answers your question.
Inventor 2012 Certified Associate
AutoCAD 2012 Certified Associate
Product Design Suite Ultimate 2012 & 2013
Other than THAT, Mrs. Lincoln, how was the play??
Illinois: Where we send more Govenors to prison, than on to retirement!
