• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    dpsmith85
    Task Scheduler "unresolved references" error message
    439 Views, 5 Replies
    09-29-2011 01:36 PM
    I am looking to batch convert my IDWs to AutoCad DWGs without having to go through and manually open each file and save as etc.  Right now I am using the export files task to do this.  I have saved an *.ini file with all the settings I want and successfully create the task.  After running the task it fails to convert all the files giving me an error message that says "File has unresolved references".  This shouldn't be the case though because the IDW's open and reference the part/assembly files fine.  Does anyone know how to fix this issue?
    Autodesk Inventor Professional 2010 32bit edition SP3
    Thanks for the help.
    Please use plain text.
    Product Support
    VinodBalasubramanian
    Re: Task Scheduler "unresolved references" error message
    10-03-2011 03:06 AM in reply to: dpsmith85
    The error "File has unresolved references" will appear when an assembly file can’t resolve components referenced in it. By default, task scheduler will skip these files. You can force task scheduler to migrate these files by using the options in the attached screenshot.
    Vinod Balasubramanian
    Manufacturing Support Specialist
    Autodesk Support
    Autodesk, Inc.
    Valued Contributor
    dpsmith85
    10-03-2011 05:25 AM in reply to: VinodBalasubramanian
    We may be running different versions, or maybe I'm confused about where you got that options box.  If I click on options in the Export files dialog box all I see is "export files options" which only chooses the *.ini file.  See the attached screenshot.  Am I looking in the wrong place?
    Valued Contributor
    dpsmith85
    10-03-2011 05:41 AM in reply to: dpsmith85
    I did find what you were refering to in the "update design" task.  I'm still a little confused though.  Am I supposed to run a task that updates the design of all the files and then run a separate task that converts idw to dwg?
    Product Support
    10-03-2011 05:19 PM in reply to: dpsmith85
    Sorry for the confusion with the screenshot. Exactly, Since you have some unresolved references, Update your drawings with the same settings i have shown and then convert them to DWG. This might help to fix your problem.
    Autodesk Support
    Autodesk, Inc.
    Member
    01-15-2013 12:32 PM in reply to: VinodBalasubramanian
    Why does Task Scheduler (Design update & Export files) not support Vault projects ?
