• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    Task Scheduler 2013
    96 Views, 3 Replies
    12-12-2012 04:58 AM
    Why doesn't task Scheduler give you an option to convert IDW to Autocad DWG?
    It will only save IDW to Inventor DWG
    Please use plain text.
    Valued Mentor
    Re: Task Scheduler 2013
    12-12-2012 05:09 AM in reply to: smichels
    You need to select 'Export Files' to convert from idw to dwg.
    Regards
    Martin
    PDSU 2014 RTM
    Windows 7 64bit, Office 2007 Pro
    Intel i7 980x, 24 Gb DDR3 RAM
    Geforce 580GTX Graphics (Diver 310.70)
    256GB SSD OS, 80GB SSD working folder
    Space Pilot
    Active Contributor
    12-12-2012 06:18 AM in reply to: Martin_Goodland
    It worked except exported dwg to zip file... Is there an option to export to dwg only.
    Active Contributor
    12-12-2012 06:40 AM in reply to: smichels
    Martin,
    I figured it out with your help.
