• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Tapered Coil
    324 Views, 11 Replies
    11-05-2012 04:34 AM
    Heyy there,
    Im using Inventor 2013 and im trying to make a tapered coil but instead of creating it with a liner taper i want a curved taper. Is there a way to create this (prehaps using guide curves like loft feature?)
    Im new to inventor but have been using solidworks for a while any help would be appreciated.
    Please use plain text.
    Cadmanto
    Re: Tapered Coil
    11-05-2012 05:25 AM in reply to: EdwardCChamberlain
    Edward,
    Welcome to the forum.
    Have you tried using the coil command under the Model tab?
    Best Regards,
    Scott McFadden
    (Colossians 3:23-25)
    Valued Contributor
    Mark.Downes
    Re: Tapered Coil
    11-05-2012 06:19 AM in reply to: EdwardCChamberlain
    this is an old technique used on other software but works. 3D sketch a helix, 2D sketch a profile shape, surface sweep a line and project the intersect for your new path.
    Hope this helps
    Cheers
    Mark
    Inventor 2013
    yes, and i have even used the taper bit of that but the p...
    11-05-2012 06:41 AM in reply to: EdwardCChamberlain
    yes, and i have even used the taper bit of that but the problem i have is that it creates a taper that comes out at an exact angle from the origin in a straight line. I need the taper to come out and taper along a curve.
    another way of saying it would be that it tapers at 10deg which then gradually decreases to 5deg as the spiral increases.This would create a shape like a flower bud or light bulb.
    I will have a go at this later and see if i can get it to...
    11-05-2012 06:42 AM in reply to: Mark.Downes
    I will have a go at this later and see if i can get it to work :smileyhappy: will report back
    Re: I will have a go at this later and see if i can get it to...
    11-05-2012 07:12 AM in reply to: EdwardCChamberlain
    If you can't get it worked out - attach your attempt here.
    Inventor Professional 2014 Edu 64-bit
    Re: Tapered Coil
    11-05-2012 10:14 AM in reply to: EdwardCChamberlain
    im struggling to create the surface sweep.
    If you could make a video, or series of screen shots of the steps it would be brillient :smileyhappy:
    Thanks Ed.
    Cadmanto
    Re: Tapered Coil
    11-05-2012 10:21 AM in reply to: EdwardCChamberlain
    Do you have an image if what you are trying to model?
    Best Regards,
    Scott McFadden
    Re: Tapered Coil
    11-05-2012 10:32 AM in reply to: EdwardCChamberlain
    Thanks Ed.
    Attach something here. Anything you have attempted.
    2d sketch
    Line
    Coil
    Surface Output
    Pitch and Height (or similar)
    exit sketch
    3d Sketch
    intersection
    Sweep
    (see attached example)
    Re: Tapered Coil
    11-05-2012 10:46 AM in reply to: JDMather
    Ok heres what im trying to create and a how far a can get. Notice how the end tapers out? i want to create that but with much more of curved taper
    Im able to create the surface revolve then create a revolved solid but i cant get any of the componants to line up, for example the helix is allways wonky and wont snap to an axis? Also dont understand "3D intersection"
