• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    abilabib
    Accepted Solution
    Synchronize Balloon with Part List
    289 Views, 5 Replies
    01-02-2012 07:52 PM
    I have litte problem for synchronize ballonwith part list where some times I put single component to main assy for create detail drawing. The problem is ballon from single component must change manually for synchrone with Part List. If number changed in part list sometimes I forgot for change ballon. So it's become miss match between ballon and part list.
    Could someone explain me how to make this become synchron.
    Please see attached file.
    Abi Labib
    Please use plain text.
    *Expert Elite*
    MariaManuela
    Re: Synchronize Balloon with Part List
    01-03-2012 08:13 AM in reply to: abilabib
    What Inventor version? 2012?
    You know the BOM (Bill Of Materials)? You work with it?
    if you change item numbers in BOM you get what you need.
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    *Expert Elite*
    Curtis_Waguespack
    01-03-2012 08:25 AM in reply to: abilabib
    Hi abilabib,
    Paul Munford covers one solution at this link:
    http://cadsetterout.com/inventor-tutorials/autodesk-inventor-creating-coordinated-bom-for-large-asse...
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Valued Contributor
    abilabib
    01-03-2012 02:42 PM in reply to: Curtis_Waguespack
    Hi Curtis,
    Thanks for your link. It's very helpfully :smileyhappy:.
    Abi Labib
    Valued Contributor
    abilabib
    01-03-2012 10:40 PM in reply to: abilabib
    I had trying the methode follow your link but if I use Bom view structure (legacy) this methode isn't not work. Can you advice another methode.
    New Member
    10-03-2012 05:43 AM in reply to: abilabib
    I have better solution for this one
    Just try attached macro
    procedure is
    Give all balloon to assembly
    Draw detail view from the ipt files then balllon will come as 1
    open the maco file
    then go to ur drawing
    tools -macros, runt the macro
    select the sheet
    After that u will noticed that Balloon Synchronize
    Ganesh Kumbhar
