• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    *Dupre, Joe
    Switching between Sheet Metal and Modeling modes
    46 Views, 4 Replies
    11-21-2002 08:28 AM
    Is it OK to switch back and forth between Sheet Metal mode and Modeling
    mode? Or am I going to get bit in the butt doing this?
    I have a model that is not a sheet metal part, but I would like to add some
    punch features to it. The punch feature is only available in sheet metal
    mode. Inventor 6 SP1 allows me to switch into sheet metal mode, add the
    punch features, and then switch back to modeling mode.
    I'm just wondering if this is a legitimate way of working or if it is likely
    to cause problems down the road.
    - Joe
    Please use plain text.
    *Caldwell, Larry
    Re: Switching between Sheet Metal and Modeling modes
    11-21-2002 08:47 AM in reply to: *Dupre, Joe
    No prob!
    ~Larry
    "Joe Dupre" wrote in message
    news:906520D8D9FF20A47E6B6491D6166FB8@in.WebX.maYIadrTaRb...
    some
    likely
    > - Joe
    *Gwin, Hal
    11-21-2002 09:06 AM in reply to: *Dupre, Joe
    I do it occasionally without problems, but then I don't ever flat pattern my
    sheet metal parts, so I don't know if you will run into problems if you do
    that.
    Hal Gwin
    Mechanical Designer
    Xenogen
    *McConnell, Cory
    11-21-2002 09:17 AM in reply to: *Dupre, Joe
    See CF. I modeled this chip in 5.3 as a part. It was modeled as a
    thru-mount chip(straight leads). I had to make a die for a press to form
    the leads to make it a flush mount. To do this, I switched to a sheetmetal
    part and bent the leads and cut them off - I wanted to see how the wide
    spots on the leads would end up.
    Cory McConnell
    BJ Pipeline Inspection
    some
    likely
    > - Joe
    *DJSpaceMouse
    11-21-2002 09:28 PM in reply to: *Dupre, Joe
    I'd guess you won't have problems placing a sheetmetal feature on a
    non-sheetmetal part, but the inverse is not true. I once tried to model a
    part of heavy-guage plate (1.5" thick or so) as sheetmetal. I had no
    problem with that, but the edges needed a chamfer on them. The sheetmetal
    chamfer tool will not allow you to chamfer an edge between a face and the
    thickness of the material. It's not easy to describe but I hope you know
    what I mean. I switched the interface over to standard modeling and added
    the chamfer without a problem. However, the flat pattern would either
    ignore every feature after and including the chamfer, or Inventor would
    crash on me. This was in 5.3, though, and I haven't tried anything similar
    in 6, but I will bet it would be the same thing.
    some
    likely
    > - Joe
