• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Sweep with Guide?
    270 Views, 10 Replies
    10-07-2012 01:52 AM
    Hi All,
    I'm after some advice on which is the best way to model the attached drawing. I've tried using a sweep along a guide but can't get the desired result!
    Does anyone have any ideas (or example) thay might like to share?
    Thanks for any help in advance.
    Rob K
    Please use plain text.
    *Expert Elite*
    Re: Sweep with Guide?
    10-07-2012 04:49 AM in reply to: bobbie.k
    Attach the ipt file here of your attempt.
    Search here on wavy washer.  (this problem has been covered here many times in the past.
    Member
    10-07-2012 07:30 AM in reply to: JDMather
    Many thanks for your reply. I have looked up the wave washer discussion and I can now complete the model I was looking at.
    Rob K
    rhasell
    10-07-2012 08:19 PM in reply to: bobbie.k
    Hi
    Just saw this this, so I thought I would give it a try. (Using the sweep)
    See attached.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Member
    10-08-2012 09:42 AM in reply to: rhasell
     Hi rhasell,
    Thanks for your feedback. I like the way you have constructed the part. One more silly question! I understand the construction but how have you actually put the 3D curve in there (what commands)?
    I'll have a play around to see if I can get there by myself but if you'd wanna share then that would be great.
    Thanks for your help.
    Rob K
    *Expert Elite*
    10-08-2012 10:20 AM in reply to: bobbie.k
    Looks like a spline created in 3D sketch.
    I might have simply done a 3D intersection - no extra workplanes required.
    3 2d sketches rather than 4
    see attached.
    *Expert Elite*
    10-08-2012 10:23 AM in reply to: JDMather
    or a solution with only 2 2d sketches rather than 4.
    rhasell
    10-08-2012 03:59 PM in reply to: bobbie.k
    Hi
    Create the base sketch with req OD of 25mm with 2 points top and bottom.
    Created a point for a workplane @ 20mm radius.
    Created the workplane at above point.
    Create sketch on workplane, create 2 points, left and right.
    Create 3D sketch, create a spline between the 4 points, changed the spline fit method to "Minimum energy"
    Create the sweep profile sketch.
    Sweep the part.
    I had a look ad JD methods, all good, just different ways of doing it.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
    *Expert Elite*
    10-08-2012 07:53 PM in reply to: rhasell
    rhasell wrote:
    Hi
    The 3D curve is different.
    rhasell
    10-08-2012 09:11 PM in reply to: JDMather
    Thats what I love about Inventor as well as the forums, there is often more than one way to model a part, and when more than one person contributes, that's how we learn (Or at least I have) the different aspects and features of the software.
    I did not even consider a 3d intersection, and will store that in the memory banks for future use.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
