Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Sweep with Guide?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi All,
I'm after some advice on which is the best way to model the attached drawing. I've tried using a sweep along a guide but can't get the desired result!
Does anyone have any ideas (or example) thay might like to share?
Thanks for any help in advance.
Rob K
Re: Sweep with Guide?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attach the ipt file here of your attempt.
Search here on wavy washer. (this problem has been covered here many times in the past.
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Many thanks for your reply. I have looked up the wave washer discussion and I can now complete the model I was looking at.
Rob K
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
Just saw this this, so I thought I would give it a try. (Using the sweep)
See attached.
Reg
Autodesk Product Design Suite Premium 2014 Build 170
Intel Core i7 (950@3.07GHz)
Windows 7x64 (Home) - 12GB Ram
Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi rhasell,
Thanks for your feedback. I like the way you have constructed the part. One more silly question! I understand the construction but how have you actually put the 3D curve in there (what commands)?
I'll have a play around to see if I can get there by myself but if you'd wanna share then that would be great.
Thanks for your help.
Rob K
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Looks like a spline created in 3D sketch.
I might have simply done a 3D intersection - no extra workplanes required.
3 2d sketches rather than 4
see attached.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
or a solution with only 2 2d sketches rather than 4.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
Create the base sketch with req OD of 25mm with 2 points top and bottom.
Created a point for a workplane @ 20mm radius.
Created the workplane at above point.
Create sketch on workplane, create 2 points, left and right.
Create 3D sketch, create a spline between the 4 points, changed the spline fit method to "Minimum energy"
Create the sweep profile sketch.
Sweep the part.
I had a look ad JD methods, all good, just different ways of doing it.
Reg
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
rhasell wrote:Hi
The 3D curve is different.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thats what I love about Inventor as well as the forums, there is often more than one way to model a part, and when more than one person contributes, that's how we learn (Or at least I have) the different aspects and features of the software.
I did not even consider a 3d intersection, and will store that in the memory banks for future use.
Reg
