• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Sweep problem
    91 Views, 2 Replies
    05-24-2012 02:59 AM
    I have a problem, when I use sweep it twist around projected curve, and when I use guide face I get self-intersecting error.
    when I use helix with less revolutions I get the result but I need more revolutions.
    Diameter of profile is not bigger than diameter of helix...
    Can anyone tell me where am I doing wrong?
    Igor
    Please use plain text.
    Valued Mentor
    mpatchus
    Re: Sweep problem
    05-24-2012 06:12 AM in reply to: foxdj
    Take a look at the swept feature and see if this is what you are looking for. If it is, edit the feature an notice the selections made. Hope this works for you.
    Mike Patchus
    Inventor 2012 SP1
    Vault Pro 2013
    New Member
    Re: Swept problem
    05-24-2012 06:16 AM in reply to: mpatchus
    Thank you, this is what I was looking for...
