• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    trumpy81
    Re: Sweep problem - can't select sketch
    04-24-2012 02:44 AM in reply to: rhasell
    Reg, thanks for the reply.
    FYI, I'm not the OP, I'm simply interested in how things are labelled as being self intersecting when I can see no evidence of it in Inventor.
    In the example part, the geometry to my mind does not show any self intersecting even in the solid state. Granted, the part as drawn could not be manufactured easily, unless it were machined from solid, which would be of no advantage at all and would certainly not be cost effective, but it is possible!
    So the question remains where and how does this geometry self intersect, according to Inventor at least?
    Is Inventor seeing the 0.6mm bend radius as being impossible and then declaring self intersection or is there something else that I'm not seeing/understanding?
    I too, try to follow standard manufacturing processes when designing my own parts, but every now and then I strike this error and I can not understand why. I'm well aware of minimum bend radius, modulus of elasticity etc... for given materials so it would seem unlikely that I would break those rules, yet Inventor tells me otherwise. Of course, I have made some pretty obvious errors, but a lot of the time they are not so obvious and they're the ones that bug me ... lol
    Regards
    Andy M
    Autodesk Inventor 2013 Pro SP1.1, Win7 Pro - 64Bit - SP1, Intel i7 960 @ 3.333 GHz
    Asus X58 Sabertooth, Corsair 12Gig DDR3, AMD Radeon HD6970, Samsung 830 Series 256G SSD, 2x 3TB Seagate, 2x 2TB Hitachi,
    1x 1TB Samsung, 4 x 2TB Seagate in Netgear ReadyNAS NV+, Dual Asus VE278Q Monitors
    Please use plain text.
    rhasell
    04-24-2012 04:16 AM in reply to: mbus0013
    Have to agree on Inventor not doing what I ask it to do, or a part breaking a few months down the line, but nine times out of ten, its my fault. Occasionally I dump it and try another route with the same/better results.
    This forum is great, I have learnt so much from it, thanks everyo, though I still have unanswered questions with the forum and Autodesk.
    Reg.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    04-24-2012 05:07 AM in reply to: trumpy81
    trumpy81 wrote:
    Next point, you cannot use a 2D sketch and a 3D sketch for the sweep command (as far as I know anyhow).
    Of course you can.  You might go through the tutorials in my signature (Knot comes to mind).
    04-24-2012 05:08 AM in reply to: trumpy81
    trumpy81 wrote:
     I have had some errors reporting self intersecting lines etc... but I could not see any evidence anywhere that a line or other geometry was intersecting itself.
    Attach file here that exhibits this behavior.
    mbus0013
    04-25-2012 02:38 AM in reply to: trumpy81
    I have edited the holes on the rim, thanks for pointing that out
    I have increased the radius of the curve
    But no matter what circle I sketch, when I click sweep and try to select is as profile it just won't select it! I can't understand why
    04-25-2012 04:28 AM in reply to: mbus0013
    Attach the new file here.
    mbus0013
    04-30-2012 05:57 AM in reply to: JDMather
    In the end I started the wheel from scratch, used a similar method and had no problems with the sweep.
    I still don't know why I kept getting this problem but at least I don't have to solve it anymore.
    Thanks everyone for trying to help.
    04-30-2012 06:27 AM in reply to: mbus0013
    Your sweep would have created a self-intersecting body.  It could have been fixed.
    Employee
    GlennChun
    04-30-2012 11:13 PM in reply to: mbus0013
    Back to the original question using your wheel 24.ipt, the reason why you couldn't easily select the circle in Sketch13 as a sweep profile is that there are too many visible sketches that can be a sweep profile.  Especially, the huge circles in Sketch6 get highlighted first as a sweep profile.  If you turn off the visibility of Sketch6, the small circle in Sketch13 can be easily selected.  Otherwise, you could zoom in the small circle and right-click > Select Other > 2. Profile Body.
    HTH,
    Glenn
