Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Surfacing Difficulti es
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am new to surfacing in Inventor. I have gotten the attached part to this point.
What I am trying to do (to no avail) is close the gab as shown below.
I tried doing a patch, but because the area is apparently not a completely enclosed loop it is not working. I tried revolving a surface that intersects the existing, but I cannot get that to trim.
I would greatly appreciate any advise on how to resolve this.
Scott McFadden
(Colossians 3:23-25)
Re: Surfacing Difficulti es
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You should normally be able to just loft a new surface between the edges (create 3d sketches and loft between them as selecting surface edges is buggy) but your composite geometry has an overlap. Zoom right in to see.
The work around is to trim the spigot back a bit to get rid of the overlap, and then create the loft. I usually offset the surfaces with 0 offset just to keep it more stable.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Steve.
Coming from Solidworks, I am struggling a bit with the Inventor surfacing tools.
I do see there is an overlap like you pointed out, but I am still struggling to get these
surfaces trimmed. I have sucessfully thickened the surfaces and still have the void.
I am now going to try and fill the gap within the solid geometry and forget the surfacing
for this portion.
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Steve,
After thickening the part I was able to create a surface within the void.
But now it won't thicken because it says it is unable to blend everything together. I will never understand why when
the preview shows it perfectly, it will not produce the geometry. ![]()
What I ended up doing (which is not ideal, but works) is creating a boundary surface on the inside and outside and changing the transparency to off then making it the same color as the geometry and that is blending in nicely.
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
First I'm no surface guru.
What I did was copy your composite into Comstruction and deleted all of your revole surfaces. Ithen went into Edit Construction.
Next I deleted the fillets surfaces from the large tube to the smaller tubes. I now did boundary patch from the small tubes to the edges on the large tube. I change the condichion to tangent.
After all Patches I then Stitch everything together and copied it back.
I could then thicken your part
Inventor 2013
GeForce GTX 580
Windows 7 64 Bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Doug,
That is a lot of work!!!
Nice job though. I am really surprised that it is this much of an effort to get something that looks to be relatively easy.
Even with what you did, while it still worked I can't imagine that it is supposed to be this complicated.
I will investigate your model further, but it looks like all ties to the original surfaces that it came from were lost.
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Patch worked here, but I can't figure out why you are doing so much work to create simple geometry?
Inventor Professional 2014 Edu 64-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
JD,
It looks simple in and of the part itself, but understand that this part I am trying to create is a lining
for the pipe assembly with a specific thickness. It needs to follow the contour of the inside of the pipe
assembly with a controlled overlap out of the flange ends.
Scott McFadden
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I still think you are going about it the wrong way (for Inventor or for SolidWorks) - doing too much work.
