• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    rhasell
    Surfaces visible in IDW
    210 Views, 3 Replies
    09-09-2012 04:24 PM
    Hello all
    I have a strange and sometimes irritating issue.
    Some of my parts are derived surface parts, I then create solids from the surfaces.
    The problem I have is:
    - The surfaces sometimes come through by default on my drawing views, I then have to track the offending part down and switch off the visibility of the surface
    - On the odd occasion, I have not been able to switch off the surface visibility, and the only work around was to derive the derived part into a new part and use that.
    Notes:
    I am not sure if the surface visibility is switched off when placing the parts in the Assemblies. (Can't remember)
    I work with tensile membrane structures, these surfaces are sometimes huge, with millions of individual triangles creating a mesh, depending on the size of the membrane, I will choose not to dislay the surface as Inventor cannot handle the calculations.
    Is there a setting to have this switched off by default, I have perhaps missed?
    Thanks.
    Regards
    Reg
    Autodesk Product Design Suite Premium 2013 sp1.1 (1)
    Intel Core i7 (950@3.07GHz)
    Windows 7x64 (Home)
    12GB Ram
    Nvidia GeForce GTX 560 Ti (1Gig - Ver:314.07)
    Please use plain text.
    CAD-One
    Re: Surfaces visible in IDW
    09-09-2012 07:14 PM in reply to: rhasell
    There might be better approach or solution. But, one of the work around to have surfaces not show jn drawings is to use delete bodies.
    In the part file use delete bodies and stkect the surfaces. Now you will find only the solids on drawing.
    C1
    Inventor Professional 2013
    Vault Collaboration 2013
    rhasell
    09-09-2012 08:00 PM in reply to: CAD-One
    Hi
    Please explain the Delete body method, are you refering to a multi-bodied part ? If so, I use this method as well.
    Below is a small example of my method of deriving a surface model.
    Regards
    Reg
    Windows 7x64 (Home)
    12GB Ram
    CAD-One
    09-09-2012 10:46 PM in reply to: rhasell
    In the part file; when you can see both surface and solid start the delete face command.
    http://docs.autodesk.com/INVPRO/2010/ENU/Autodesk%20Inventor%202010%20Help/index.html?url=WS1a919382...
    C1
