• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Member
    Accepted Solution
    Surface Cuts
    244 Views, 2 Replies
    04-05-2012 12:56 PM
    I'm trying to make a surface cut on my part.  The part is a round cylindrical shaped cap with a surface geometry going through the center.  I want to make that surface geometry remove some of the cylindrical part by about half the wall thickness.
    See the attachment of the picture "cap" for a picture with the surfaces I'm speaking about.  The orange features are surfaces and the grey feature is just a solid cylinder that I want to cut. The vertical, cylindrical surface in orange is where I want the grey cylinder to be cut along the curved orange surface.  Only on the grey area outside of the orange cylindrical surface is to be cut while leaving everything grey on the inside area of the cylindrical surface will remain.
    The picture titled "ideal cap" is the look that I'm going for on the picture titled "cap" which I'm trying to perform this cut on.  The picture titled "ideal cap" was made using Pro/E and I'm trying to mimic the same thing in Inventor.
    Does anyone know how I can do this?
    Please use plain text.
    *Expert Elite*
    Curtis_Waguespack
    Re: Surface Cuts
    04-05-2012 01:18 PM in reply to: m209112
    Hi m209112,
    Here are a couple of examples that illustrate two different methods for this kind of thing.
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Member
    Re: Surface Cuts
    04-06-2012 04:22 AM in reply to: Curtis_Waguespack
    Thans Curtis! The were great examples to explain how it can be done!
    Curtis_Waguespack wrote:
    Hi m209112,
    I hope this helps.
    Curtis
