• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    bukko
    Suppressing Patterned Occurrences Question
    50 Views, 2 Replies
    02-22-2012 05:00 PM
    I have a patterned extrusion in a part. I need to supress the first occurence in this pattern but the option to do so in the context menu is not available when right clicking the 1st occurence  The remaining occurences are suppressable. Is this normal behavoir when patterning in a part file?
    Thank you
    Craig
    Active Member
    bukko
    Re: Suppressing Patterned Occurrences Question
    02-22-2012 05:11 PM in reply to: bukko
    I just found my answer...... can't suppress the first occurence. ;-(
    What would be a good stategy around this pattern behavior?
    Any suggestions would be greatly appreciated.
    Regards
    Craig
    Valued Mentor
    02-22-2012 05:15 PM in reply to: bukko
    Yes this is normal behaviour in terms of a patterned feature. Unfortunately you can not also break a pattern feature.
    However, you can pattern a sketch and untick associative to break the sketch pattern.
    Then extrude all the sketch profiles.
