• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Contributor
    nickhowe
    Super Long Datum Planes
    104 Views, 2 Replies
    11-19-2012 07:54 AM
    I have found after my last save, the Datum Planes of the assembly have just lengthened in two directions monstrously for no reason. I checked to see if it was an unassebled straggler but cant find anything. Is there a way of knowing why it does this.
    Check attached image, the dot is a machine 20 metres high and the datum plane seems to reach the nearest neighbourhood for some reason.
    Cheers
    Nick
    Please use plain text.
    Valued Mentor
    stephengibson76
    Re: Super Long Datum Planes
    11-19-2012 07:58 AM in reply to: nickhowe
    if the datums on the parts are set to auto resize, then it could be in the part sketch, maybe some projected geometry, try opening each one seperatly.
    Stephen Gibson
    Autodesk Product Design Suit 2012
    Win 7 Enterprise 64bit
    Intel core i7 2600K Clocked @ 4.7GHz
    16Gb Ram
    Nvidia GTX 580
    Active Contributor
    nickhowe
    11-19-2012 08:09 AM in reply to: stephengibson76
    .... They were set to Automatic update. I found the problem though, I took the constraints off a suspect part and it was a tangent constraint throwing out the planes. All great now.
    You live and learn!!
    Thanks anyway :smileyhappy:
