• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    eveylynne
    Accepted Solution
    Styles editor idiot moment
    220 Views, 4 Replies
    04-03-2012 10:15 AM
    Long short, I wanted to rename one of the default layer, "Visible," to "CUT" since that's what our plasma cutter looks for.
    However, I created a copy of Visible named CUT.  Now when I open a new drawing, I get the usual, "The following definitions in template Blah differ from the definitions in the style library..."
    I know I could update each template, but I'd rather just delete the copied layer in the styles library.  However, I don't see how.  Any tips on removing my extra layer with out starting from scratch? Or how to rename a default layer?
    Thanks!
    Please use plain text.
    *Expert Elite*
    Cadmanto
    Re: Styles editor idiot moment
    04-03-2012 11:09 AM in reply to: eveylynne
    Did you try RCing on the layer in the styles and standards editor and purging it?
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    Valued Contributor
    eveylynne
    04-03-2012 12:13 PM in reply to: Cadmanto
    Yeah, nothing shows up to purge. :smileysad:
    (moments later)
    However, I appernetly just needed to relaunch Inventor.  It worked this time around! thank you!
    *Expert Elite*
    Cadmanto
    04-03-2012 01:20 PM in reply to: eveylynne
    Your welcome.  Glad it worked out for you.
    Best Regards,
    Scott McFadden
    hareshbhere
    Style not updating for Old Drawing
    12-22-2012 01:40 AM in reply to: eveylynne
    I have renamed one of the layer from "Engraving" to "UBENDLINE" as our laser is looking for. Now I have to update all old drawing for new layer.
    When I tried to update old drawing for styles, it is not updating style i. showing old layer "Engraving". Same I tried with new drawing, it is showing correct layer as expected.
    Please suggest me solution for updating old drawings.
