• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Distinguished Contributor
    Re: Studio Reflective Gp shows cut reflection
    07-26-2006 02:04 PM in reply to: mf1362
    can you post a pic of the screen before you render?
    Please use plain text.
    *Randy Kreitzman (Autodesk)
    07-26-2006 02:46 PM in reply to: mf1362
    Marco,
    Could you try inserting an extruded rectangle into the scene, assign it
    a highly reflective surface style, and place it beneath your assembly?
    This may be an issue with how big your assembly is in relation to the
    Inventor universe. The shadow/reflection plane isn't infinite, but it
    is very, very big.
    I wouldn't expect to see this phenomenon unless the assembly were huge.
    Thank you,
    -Randy
    mf1362 wrote:
    > Results don't vary when zooming in or out, the plane looks complete before rendering
    07-26-2006 03:43 PM in reply to: mf1362
    see attached pic before rendering -Marco
    07-26-2006 03:52 PM in reply to: mf1362
    Well, I did a new rendering with an extruded 12" rectangle, and the shadow & reflection look good. But when I removed the bar it came back to the same cut reflection. (weird). see attched files
    -Marco
    07-26-2006 03:53 PM in reply to: mf1362
    Here's the other pic
    07-26-2006 04:04 PM in reply to: mf1362
    It looks like the shadow/reflection plane is, in part, defined by the
    extents of the scene geometry. Try placing any renderable geometry out
    of the camera view but a good distance away from your assembly.
    -Randy
    07-27-2006 07:44 AM in reply to: mf1362
    Couldn't or can't?
    If you can then roll up the EOP, Zip and post.
    Active Member
    01-03-2013 05:51 AM in reply to: *Randy Kreitzman (Autodesk)
    I had the same issue and knew it must have had something to do with the size of the assembly. Mine was a full-size combined cycle power facility that I was rendering to an existing site image. It was just big enough that when offset to a side of the background image that the shaddows would be clipped.I will try creating a derived assembly at half-size for the scene.
