• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Studio Reflective Gp shows cut reflection
    109 Views, 17 Replies
    07-25-2006 04:00 PM
    I have a problem with Inventor 11 Studio. The reflection on the ground made by "XZ Reflective Gp" works in a way that when rendered, it shows a partial or cut reflection of my assembly, see attached .jpg file. I have not found yet where this "reflection depth" is regulated. Please help! -Marco
    Please use plain text.
    Distinguished Contributor
    Re: Studio Reflective Gp shows cut reflection
    07-26-2006 06:42 AM in reply to: mf1362
    In studio, go to Scene Styles, select your scene, then on the Environment tab, select the Ground Plane direction and offset.
    -barrett
    07-26-2006 10:30 AM in reply to: mf1362
    I tried that before, but as you can see in the attached .jpeg file, the problem is not the degree of reflection or the distance of the plane to the base of the object, the problem is the reflection is not shown entirely on the rendering, it is cut across the bottom of it. -Marco
    07-26-2006 10:32 AM in reply to: mf1362
    ...and this is also happening to the shadow, as you can see. -Marco
    07-26-2006 11:05 AM in reply to: mf1362
    Hi Marco,
    Could you post the part?
    *Gary R Smith \(Autodesk\)
    07-26-2006 12:31 PM in reply to: mf1362
    Does this behavior manifest in all renderings or only of this part?
    Have you tried rendering using any of the other reflective planes? Do they
    clip too?
    When you click on the render button, does the plane appear to be full-sized?
    07-26-2006 12:34 PM in reply to: mf1362
    How big is the part?
    Do your results vary if you zoom out on the part? Can you get "more"
    reflection/shadow to render?
    07-26-2006 12:54 PM in reply to: mf1362
    a .jpeg is posted, couldn't post a 3d file (?) -Marco
    07-26-2006 12:56 PM in reply to: mf1362
    It happens only on this part so far, but I only have a couple of days experience with Inventor studio, so I have done about 6 parts so far
    07-26-2006 12:57 PM in reply to: mf1362
    Results don't vary when zooming in or out, the plane looks complete before rendering
