• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    New Member
    Accepted Solution
    Student has messed up the browser language so how can i ........
    142 Views, 2 Replies
    01-11-2013 10:38 AM
    A student has stumped me but not with something cool or exciting.  He has changed a custom feature and I can’t figure out how he did it.  It also brings up another thought about a better way to fix this kind of problem because I am sure to have many more like it.  Here goes.
    The student has changed the language of his inventor 2013 browser to show another language.  I think it is dingbats or something similar.  This change is only affecting the browser and the “Applications Options” dialogue box. (this also means I can't read the text in the options box) I am sure there are other areas but strangely all the ribbons are still in English.  Thoughts?
    I started to look at just copying the INI file from a working computer to overwrite his ini file but can't find it.  Or, is that a bad idea and there is a better way?  In the first paragraph I mentioned a better way to fix this kind of problem.  With our last version (V 14 ??) AutoCAD I would just replace the default drawing first and if that didn't work I would replace the INI.
    So any suggestions on how he did this and a good method to overwrite setup files that might fix similar problems?
    BTW, I have had his profile deleted but it didn't change anything and he can log into another computer and the files are fine.  So it is a setup feature of the one computer.
    Please use plain text.
    Distinguished Contributor
    LT.Rusty
    Re: Student has messed up the browser language so how can i ........
    01-11-2013 11:59 AM in reply to: 7997redtail
    See where the font is in my picture below?  Change that to something else.  Even if you can't read what the font name says, chances are very good that no matter what you change it to will at least be in a readable language.  Once you can read it, change it back to Arial or whatever font you like.  Note the position of the Apply button in the menu - that's the button you'll want to click.
    You shouldn't need to change the .INI files or anything ...
    ___________________________________________________________
    Product Design Suite Ultimate 2013
    Dell Precision T1600 (Xeon E3-1280 / 16GB / 512 GB SSD / 250 GB (Internal) / 1 TB (External) / Quadro 600)
    Toshiba Satellite P755-S5269 (i7-2630QM / 8 GB / 250 GB SSD / 750 GB HDD / GT540M)
    New Member
    01-11-2013 12:12 PM in reply to: LT.Rusty
    LT. Rusty your awesome.  I just told the student that did this that he owes you a beer.  Unfortunatly, he is only 15 so you might have to wait a few years. :smileyhappy:
