• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Accepted Solution
    Stuck on JD Mather tutorial
    296 Views, 2 Replies
    12-21-2012 04:12 AM
    Greetings all
    I am working my way through JD Mather's tuts, thanks to the project files he very speedily sent me.
    I am on tut 11, cylindrical cam, point 10 - Extrude the outer ring to the spline surface.
    Everything else has gone like clockwork, but I now get "extrusion distance is zero.Use Edit Extruded Feature to change the extrusion distance."
    I have re-tried a couple of times up to this point, but I can't see what I'm missing.
    I will attach my attempt.
    P.S. I have learned more about surfaces in 2 days than in the last 6 months of using/abusing Inventor.
    - Inventor 2013 Pro
    Please use plain text.
    *Expert Elite*
    Re: Stuck on JD Mather tutorial
    12-21-2012 05:34 AM in reply to: BarryZA
    Looks like the behavior has changed since I wrote that tutorial.  The direction arrow is wrong.  (looks like a bug in the progam to me)
    Try using Between instead and select the end of the cylinder and select the surface.
    BTW- there are now two different and easier techniques to model this cam.
    In a later release the Sweep with Guide Surface functionality was added
    and then
    later a Cylindrical Cam Design Accelerator was added.
    There might be some related use of this more complex technique that makes it still relevant.
    Inventor Professional 2014 Edu 64-bit
    Valued Contributor
    12-22-2012 05:33 AM in reply to: JDMather
    Thank-you again, I just knew the solution was going to fall into the "minor point that I should have worked out on my own" category.
    And I really enjoyed the vacuum tutorial, it made me realize how badly I have been modelling.
