• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Member
    Stuck in imperial
    120 Views, 5 Replies
    11-29-2012 10:57 AM
    Bare with me i am new to inventor and i am studing at college. I dont know how but i seem to stuck in imperial. Every time i start a new drawing i have to go tools>document settings>units and change to metric. is there anyway i can make this change permanent? Any help would be appreciated.
    Please use plain text.
    Member
    Re: Stuck in imperial
    11-29-2012 10:59 AM in reply to: rmfabrications
    I forgot to add i am using Inventor 2010
    11-29-2012 11:05 AM in reply to: rmfabrications
    Find the Templates folder and replace the Standard.ipt file with the Standard(mm).ipt file and rename it as Standard.ipt
    You will probably want to do this for the assembly, drawing and ipn templates as well.
    (in later versions (and maybe 2010) you can Save Copy As Template to replace the standard template.)
    BTW - when you installed the software there was an option at that time to set your Standard units.  Later versions made it easier to change after installation.
    Cadmanto
    11-29-2012 11:10 AM in reply to: rmfabrications
    Another thing you are going to want to do is if you create your own templates (as you should to secure these settings)
    the folder you place them in needs to be pathed inside of your master project file.
    The other thing you should look into is change settings inside of the styles editor possibly creating new styles if necessary.
    There are videos on youtube that may help you in doing this.
    Good luck.
    Best Regards,
    Scott McFadden
    (2 Corinthians 5:21)
    *Pro
    jletcher
    11-29-2012 11:47 AM in reply to: JDMather
    JD if I read this right he is needing this for drawings not part.
    So he will need to set up an IDW template and styles and then save back to templates. and save styles.. This way the default style would be mm.
    James Letcher
    2012 Factory Design Suite ( will not load 2013)
    What happen to my Inventor :-(
    Member
    11-29-2012 11:50 AM in reply to: jletcher
    Sorry my wording is poor. i was refering to the part. well to be honest i was refering to everything i made a boo boo when i installed the software in would seem. i have now resolved the issue thanks for all your help
