• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    weiloon
    Structural shape Authoring issue
    184 Views, 5 Replies
    01-22-2013 06:00 PM
    HI GOOD DAY to all the Autodesk Inventor Experts,
    A question here regarding frame design feature in Autodesk Inventor. i have my own company structural shape and wanna publish it into the Autodesk Inventor library therefore i can insert it by using the frame feature in design acceleralator.
    i know that we can author the structural shape, but how to author the structural shape together with the slots and holes along the frame as below.
    Please use plain text.
    Distinguished Contributor
    BLHDrafting
    Re: Structural shape Authoring issue
    01-22-2013 07:33 PM in reply to: weiloon
    Although I don't do it myself, here is a blog topic that I read recently that says that iLogic and Content Centre play nicely together. If you create the holes/slots by iLogic then I think this will help.
    http://cadprosystems.blogspot.com.au/2012/11/inventor-ilogic-and-content-center-they.html
    Brendan Henderson
    Web www.blh.com.au
    Twitter @BLHDrafting
    Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
    ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD
    Inv R2013 PDS SP1.1 Update 2, Vault 2013 Workgroup Update 1
    Valued Contributor
    01-23-2013 11:12 AM in reply to: weiloon
    It's very easy!
    use the following steps
    1 Creatie your base exstrusion in One single exstrude feature
    2 autor the part
    3 create aditional features, like patterns.
    succes
    BLHDrafting
    01-23-2013 12:23 PM in reply to: weiloon
    Hi Weiloon.
    Although you don't say what Inventor version you're on I have created a 2012 part and published it to my CC, complete with length adjustment and patterned holes/slots. You should be able to figure it out from this. See attached.
    Brendan Henderson
    Web www.blh.com.au
    *Expert Elite*
    01-23-2013 12:27 PM in reply to: BLHDrafting
    ....are you guys sure this will work with the Frame Generator?
    I would be impressed by an example!
    Inventor Professional 2014 Edu 64-bit
    BLHDrafting
    01-23-2013 02:09 PM in reply to: JDMather
    Yep, shot myself in the foot. Forgot about the Frame Generator part of the post. Publishes to the CC okay but that's only part of the requirement   :smileysad:
    Brendan Henderson
    Web www.blh.com.au
