• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    MariaManuela
    Stress calculations based on standards
    253 Views, 8 Replies
    11-17-2011 09:53 AM
    Hi
    Anyone know if inventor Simulation can do stress calculations based on standards / rules ?
    Thanks.
    Maria Manuela Pinho
    Application Enginner
    Cadtech.Asidek | Autodesk Gold Partner
    http://cadtech-asidek.blogspot.com/
    www.cadtech.pt | www.cadtech.es | www.asidek.es
    Autodesk Inventor Professional 2013
    Windows 7 Professional 64-bit
    Please use plain text.
    Re: Stress calculations based on standards
    11-17-2011 09:59 AM in reply to: MariaManuela
    What standards?
    What rules?
    MariaManuela
    11-17-2011 10:06 AM in reply to: JDMather
    FEA standards.
    Maria Manuela Pinho
    11-17-2011 11:14 AM in reply to: MariaManuela
    What FEA standards?
    Cite url of the standards.
    I can tell you that in my class we do all of our analysis in Algor (now Autodesk Simulation), Pro/E (now Creo), SolidWorks and Inventor and get equivalent results in all 4 programs (for the types of problems we do - Inventor has limitations on types of FEA analysis it can do that aren't in say, Algor).
    Employee
    11-17-2011 02:31 PM in reply to: JDMather
    We have whitepapers published comparing AIP Stress Analysis to NAFEMS cases.  Is this what you're looking for?
       http://usa.autodesk.com/autodesk-inventor/white-papers/
       Direct link: http://images.autodesk.com/adsk/files/autodesk_simulation_2011_nafems_benchmarks.pdf
    Thanks, -Hugh
    *Please press the 'accept as solution' button if this thread answers your question, so others can quickly benefit*
    Hugh Henderson
    Simulation QA Engineer
    DLS (Simulation and Material Sciences)
    Valued Mentor
    jeanchile
    08-16-2012 07:32 AM in reply to: henderh
    Hugh (or anyone else),
    I have an audit coming up and I was wondering if you have any white papers for Inventor's frame analysis tools. Does anything similar to what you posted here exist for that function of IV (preferably 2011)?
    Thanks for the help and your incredible expertise in this area!
    Inventor Professional 2013 (SP-1.1), Product Design Suite Ultimate
    Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (314.07), Space Pilot Pro (3.16.1)
    Laptop: Intel Core 2 Duo T9600 @ 2.8GHz, 8.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTS 160M (314.07), SpaceNavigator (3.16.1)
    Employee
    08-16-2012 09:39 AM in reply to: MariaManuela
    Hi Jean,
      I can say that we've done substantial internal numerical validation of the Frame Analysis results.  However, these are not included in the 2012 NAFEMS whitepaper or the upcoming R2013 whitepaper that should include a Frame Analysis modal result comparison.  I'm looking into the possibility of including FA numerical results in the upcoming R2014 NAFEMS comparison.
      The Beam element solver used in Inventor's Frame Analysis is the same one we use for our Autodesk Robot Structural Analysis product.  I've looked for Robot result benchmarks, and so far the closest I can find is a (non-Autodesk published) verification with respect to US codes here.
      I hope this helps, and we appreciate you bringing this to our attention!  As always, please let us know if you have any additional questions, comments or concerns.
    Best regards, -Hugh
    Hugh Henderson
    Valued Mentor
    jeanchile
    08-16-2012 10:15 AM in reply to: henderh
    Thank you Hugh. They haven't asked me specifically for the frame analysis documentation but I suspect they might. If they do I will get them the information you posted here. Becuase of our auditing requirements it would be awesome to have one document that satisfied all of these "verified software results" requirements that are being added to our list each time. For some reason these auditors don't trust software companies :smileyhappy:!
    Your analysis knowledge is a valuable asset to this forum and I thank you for your participation! Have a good day.
    Distinguished Mentor
    08-16-2012 07:09 PM in reply to: jeanchile
    Neither should you, if your design fails because the software is in error then the responsibility is with you, not the software manufacturer. Part of quality assurance standards requires that all your in-house and proprietary software has been verified to be accurate. Part of our compliance with ISO 9001 requires us to perform this for all our engineering software.
    Although I agree, you would like to think that the software companies have fixed all the errors but this is often not the case. At least with FEA these errors don't usually influence the benchmarks. With some of the proprietary PV software though this hasn't been the case.
    Please mark as "Accept as Solution" if it answers your question or "Kudos" if you found it useful.
    Stew, AICP
    Inventor Professional 2013, Autodesk Simulation Multiphysics 2013
    Windows 7 x64 Core i7 32GB Ram FX2000
