• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor
    Stress calculation Inventor 2010
    220 Views, 5 Replies
    01-22-2010 01:38 AM
    Hi
    I have a problem when calculating thinn sheet metal designs.
    It seams there is a problem with the meshing but I cant solve it
    The part i am working on now has 1,25mm thick material and when I run a simulation I emidiately get an error for the meshing.
    se attached picture.
    This example has a bend applied but i get this error message even on flat sheets
    How do i solve this problem?
    Please use plain text.
    Distinguished Contributor
    Re: Stress calculation Inventor 2010
    01-22-2010 04:03 AM in reply to: Mustang69
    Much Easier if you post the actual file
    Distinguished Mentor
    01-22-2010 07:47 AM in reply to: Mustang69
    The issue is that your part is very thin compared to its length and width. Try to refine your element size so that you can have several elements across the minimum dimension of your part.
    The FEA in IV2010 does not have 2d plane elements which would be a better choice for large sheetmetal parts. You may have to look into a standalone package to get the results you want.
    **Master
    01-22-2010 09:11 AM in reply to: Mustang69
    If I'm not mistaken you can use the Local Mesh Control in 2010 to manually mesh certain faces where needed.
    Also I think in the past I've found that unchecking the setting for small geometry features helped with this, but I'm going from memory.
    Either way I'd check the mesh settings and adjust as needed.
    **Master
    01-22-2010 09:17 AM in reply to: Mustang69
    also, it looks like you may be running the FEA on the assembly. If so there is an option to mesh based on the part dims rather than the assembly dims that may be helpful. I think that's in the mesh settings too.
    02-01-2010 05:16 AM in reply to: Mustang69
    does anyone know what is the maximum allowed element distortion (element maximum dimension / minimum dimension) in 2010? This applies to thin-walled part where you get the error message like Mustang69 relatively easily. I know this element type is not actually meant for thin-wall analysis, but it is the only one included...
    Veikko
