• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Valued Contributor hlo
    Valued Contributor
    Accepted Solution
    Stress analysis - deflection of a steel block
    276 Views, 4 Replies
    11-19-2012 03:21 AM
    HI
    Is it possible to calculate the deflection a steel block will get, just form it one weight
    Just use standard steel material, it is only supported at the end.
    Regards
    Henrik
    Please use plain text.
    Product Support
    Re: Stress analysis - deflection of a steel block
    11-23-2012 07:11 AM in reply to: hlo
    Yes, it is possible. I assume you want to place the Weight positioned along the bar at a set distance.
    You can do this by splitting the face with either a circle or rectangle and placing your force there.
    I have attached an example. Hopefully I have understood your question.
    Jon.
    Jon Dean
    Support Specialist
    Product Support
    Autodesk, Inc.
    *Expert Elite*
    blair
    11-23-2012 11:58 AM in reply to: jon.dean
    Remember to add the directionof gravity to your analysis (if applicable).
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Valued Contributor
    11-25-2012 12:06 AM in reply to: blair
    HI
    Hi
    Thank for reply, i do understand the estimated setup and way to get a bending result
    The gravity vector where shout it be placed in this example
    Another question regarding the use of split tool, what dose I do to the surface, is it only
    marking a round spot and not removing  anything.
    Regards
    Henrik
    *Expert Elite*
    blair
    11-25-2012 10:47 AM in reply to: hlo
    The Gravity Vector is just that, the direction/vector that gravity will affect the model in question. It doesn't matter which object/edge you select. If an edge is not in the correct direction, you can expand the box and enter a vector using the XZY boxes.
    You need to create a sketch on the desired surface and then create a closed loop then exit the sketch. Select the Split Tool command, then the sketch (closed profile) and finally the surface in question.
    If you wish to apply a load to a given spot/area on a surface, you would be required to use the Split Surface to create a separate surface in which to apply either the force/load or support constrain. Otherwise Inventor will apply the load/constrain to the whole surface face.
    Win7-64
