Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Stress analysis - deflection of a steel block
- Highlight
- Email to a Friend
HI
Is it possible to calculate the deflection a steel block will get, just form it one weight
Just use standard steel material, it is only supported at the end.
Regards
Henrik
Re: Stress analysis - deflection of a steel block
- Highlight
- Email to a Friend
Yes, it is possible. I assume you want to place the Weight positioned along the bar at a set distance.
You can do this by splitting the face with either a circle or rectangle and placing your force there.
I have attached an example. Hopefully I have understood your question.
Jon.
Jon Dean
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Remember to add the directionof gravity to your analysis (if applicable).
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
- Highlight
- Email to a Friend
HI
Hi
Thank for reply, i do understand the estimated setup and way to get a bending result
The gravity vector where shout it be placed in this example
Another question regarding the use of split tool, what dose I do to the surface, is it only
marking a round spot and not removing anything.
Regards
Henrik
- Highlight
- Email to a Friend
The Gravity Vector is just that, the direction/vector that gravity will affect the model in question. It doesn't matter which object/edge you select. If an edge is not in the correct direction, you can expand the box and enter a vector using the XZY boxes.
You need to create a sketch on the desired surface and then create a closed loop then exit the sketch. Select the Split Tool command, then the sketch (closed profile) and finally the surface in question.
If you wish to apply a load to a given spot/area on a surface, you would be required to use the Split Surface to create a separate surface in which to apply either the force/load or support constrain. Otherwise Inventor will apply the load/constrain to the whole surface face.
Win7-64
