Autodesk Inventor
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Stress Analysis
- Highlight
- Email to a Friend
Hi!
I'm currently doing a project and it involves the use of a flat rectangular plate/beam. Dimension approximately about 100mm by 10mm by 2mm. A constant load will be applied on the end of the surface. I would like to find out if there is a way to find out the maximum number of times i can apply the load (after applying the load, it will be removed and applied on the same point again) to the beam until it fails? I would also like to know if i can apply mulitple loads, at different internal and achieve this too?
Thank you!
Re: Stress Analysis
- Highlight
- Email to a Friend
You will need some othe product - perhaps Autodesk Simulation.
You cannot do this analysis in Autodesk Inventor.
Re: Stress Analysis
- Highlight
- Email to a Friend
Thank you for the response JDMather
Which simulation software will allow me to find out fatigue failure? Autodesk Simulation 360 or Autodesk Simulation Multiphysics?
Re: Stress Analysis
- Highlight
- Email to a Friend
You should probably post your question over here
http://forums.autodesk.com/t5/Autodesk-Simulation-
