Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Stress Analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
My name is Pedro, I'm mechanical designer in Brazilian Synchotron Light Lab.
We are projecting a support for one mirror of our Infrared beam line. The support is a block with a rotational weak link which needs to be rotated about +/- 1°. I would like to know a way to insert this angular displacement and get the stress in the weak link area.
I dont have the moment loads and components.
I hope anyone can help me.
Thanks.
Pedro
Re: Stress Analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Pedro,
You can try using the Fixed Constraint. If you check the vectors checkbox, you can input the prescribed [x,y,z] displacement, but not rotation since the solid elements don't include rotational components.
If you have R2013 or later, and the 'weak link' geometry is considered thin, you can use Shell elements and prescribe rotations as well as displacements in the Fixed constraint command.
Hope this helps..
Best regards, -Hugh
Hugh Henderson
Simulation QA Engineer
DLS (Simulation and Material Sciences)
Re: Stress Analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Hugh,
Thank you very much for the support.
Best Regards,
Pedro.
