• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Stress Analysis
    176 Views, 2 Replies
    12-18-2012 04:47 AM
    My name is Pedro, I'm mechanical designer in Brazilian Synchotron Light Lab.
    We are projecting a support for one mirror of our Infrared beam line. The support is a block with a rotational weak link which needs to be rotated about +/- 1°. I would like to know a way to insert this angular displacement and get the stress in the weak link area.
    I dont have the moment loads and components.
    I hope anyone can help me.
    Thanks.
    Pedro
    Please use plain text.
    Employee
    Re: Stress Analysis
    12-18-2012 10:52 AM in reply to: psouza
    Hi Pedro,
      You can try using the Fixed Constraint.  If you check the vectors checkbox, you can input the prescribed [x,y,z] displacement, but not rotation since the solid elements don't include rotational components.
      If you have R2013 or later, and the 'weak link' geometry is considered thin, you can use Shell elements and prescribe rotations as well as displacements in the Fixed constraint command.
    Hope this helps..
    Best regards, -Hugh
    *Please press the 'accept as solution' button if this thread answers your question, so others can quickly benefit*
    Hugh Henderson
    Simulation QA Engineer
    DLS (Simulation and Material Sciences)
    Active Member
    Re: Stress Analysis
    12-19-2012 02:46 AM in reply to: henderh
    Hi Hugh,
    Thank you very much for the support.
    Best Regards,
    Pedro.
