Inventor Forum
Starting out - Sybex "Mastering Autodesk Inventor 2012" by Curtis Waguespack
8 REPLIES 8
Message 1 of 9
stark_uk
1606 Views, 8 Replies
Hi
I've bought the above book and am starting out teaching myself Autodesk Inventor 2012.  I've downloaded all Sybex's files for use with the book, however I've (only) got to page 21 and have got stuck!
The book says to open file mi_1a_001.iam, however as soon as I do this, it opens a window trying to "Resolve Link" which I'm guessing it means its searching for other files (like Xref's in AutoCAD) but it can't find them.  I've searched all the folders of the files I downloaded from the Sybex website, however they're not included.
Has anyone else come up against this problem?  The missing files are:
Arbor_Frame.ipt
PINION SHAFT.ipt
LEVER ARM.ipt
THUMB SCREW.ipt
TABLE PLATE.ipt
RAM.ipt
HANDLE CAP.ipt
COLLAR.ipt
GIB PLATE.ipt
GROOVE PIN.ipt
ANSI B18.3 - 1_4-20 UNC - 0.875(31).ipt
BS 4168 - M5 x 16(2).ipt
ISO 4766 - M5 x 5ISO.ipt
Thanks for any help!
8 REPLIES 8
Message 2 of 9
DarrenP
in reply to: stark_uk
are you using the correct project file?
DarrenP
Message 3 of 9
stark_uk
Hi Darren - yes, definately using the correct project file.
I've followed the instructions in the book precisely and everything's worked as it says it should up until I click OPEN and then it starts to look for what appears to be the missing files.
Message 4 of 9
JDMather
What is the url to the file download link?
Those file names sound like the Inventor Tutorial/Samples file (but with different iam file).
(that particular design was done by one of my Beginning Inventor students.)
Have you downloaded the tutorial files?
http://usa.autodesk.com/adsk/servlet/linkedsumindex?siteID=123112&id=2387188&linkID=9242016
The CADWhisperer YouTube Channel
Message 5 of 9
stark_uk
in reply to: JDMather
The url is:
www.sybex.com/go/masteringinventor2012
See the DOWNLOADS tab for the files.
I've just downloaded the 2012 sample files as per your link and they appear to be the same.
Message 6 of 9
JDMather
Did you download the Chapter 12 and extract from the Sybex website.  Chapter12\Components\
That is where it is looking for the files.
Message 7 of 9
stark_uk
I'd downloaded all the files, however had left them as ZIP files and only extracted Chapter One.  Now that I've extracted all 20 chapters, its working as is should.
Thanks very much for the help, you're a star!
Message 8 of 9
Hi stark_uk,
As JDMather mentioned the book files reused files contained in the Chapter 12 folder without anticipating that some readers would download/unzip the chapters one at a time. I'll have Sybex update the files at their download link to include a self contained Chapter 01 zip file.
Please accept my apologies for any inconvenience this has caused.
And a big Thanks! to JD for his prompt attention to this matter. Smiley Very Happy
I hope this helps.
Curtis
Message 9 of 9
Thanks Curtis; I just didn't extract all the chapter files as I thought I'd save space whilst I didn't need them - not realising that they'd reference each other.  It's all sorted now, so onto the next page!
I also emailed you directly Curtis, so please ignore that.
Thanks again!
