Autodesk Inventor
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
ok so what ive been trying to do for about a week now is make a helix that sweeps around a rectangular prism i was able to make it in solid works but i cant find a way to do it in inventor. any suggestions would help
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please post a picture of what you are trying to achieve.
IV2014.1 PDSU / Sim Mech 2014 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 314.07
SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
somethin like this
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You can try below workflow:
1. Download the attached sample excel which defines the 3D points for creating the sweep path.
2. New a part document and create a 3D sketch.
3. On the 3D Sketch tab, call Insert->Points command.
4. With the Open dialog, choose the excel and click the Options... button to change the Import Options to Create lines.
5. Click OK and Open to create the 3D sketch lines, and then click the Bend command and select each corner point to create the bend so the sweep is smooth at the corners.
6. Exit 3D sketch, and create a 2D sketch bases on XZ plane, and create a circle with its center on origin.
7. Exit 2D sketch, and create a sweep feature with the circle as profile and the 3D sketch lines as path.
Hope this helps.
Rocky Zhang
Inventor API
Manufacturing Solutions
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi blmckenzi3,
There are two example models you can find attached at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/Ma
I hope this helps.
Curtis
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
that excel file didnt work i got to the insert points commad and selected the excel file chose the create lines option hit open and nothing happened
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
how do you make things translucent? sorry im kinda new at this
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi blmckenzi3,
You can do this by extruding a profile as a surface (rather than a solid).
You might use the End of Part marker in the examples at the link to examine how the features were created one at a time.
This is often a good way to learn a new technique. Post back if you have more questions and I'm sure someone will help.
I hope this helps.
Curtis
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi blmckenzi3,
You might also see JDMather's knot tutorial for more on the general technique:
http://home.pct.edu/~jmather/content/DSG322/Invent
http://home.pct.edu/~jmather/content/DSG322/invent
I hope this helps.
Curtis
Re: Square helix??
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks everyone! oh man ive been trying to do this for almost two weeks now ![]()
