• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Inventor
    Active Member
    Square helix??
    351 Views, 10 Replies
    12-20-2012 03:55 PM
    ok so what ive been trying to do for about a week now is make a helix that sweeps around a rectangular prism i was able to make it in solid works but i cant find a way to do it in inventor. any suggestions would help
    Please use plain text.
    blair
    Re: Square helix??
    12-20-2012 04:21 PM in reply to: blmckenzi3
    Please post a picture of what you are trying to achieve.
    IV2014.1 PDSU / Sim Mech 2014 /
    Win7-64
    EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
    950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
    Nvidia GTX-690 Classified - 314.07
    SpacePilot Pro 3.16.1 / 6.16.0 / 4.11
    Active Member
    Re: Square helix??
    12-20-2012 05:16 PM in reply to: blair
    somethin like this
    Employee
    Re: Square helix??
    12-20-2012 06:37 PM in reply to: blmckenzi3
    You can try below workflow:
    1. Download the attached sample excel which defines the 3D points for creating the sweep path.
    2. New a part document and create a 3D sketch.
    3. On the 3D Sketch tab, call Insert->Points command.
    4. With the Open dialog, choose the excel and click the Options... button to change the Import Options to Create lines.
    5. Click OK and Open to create the 3D sketch lines, and then click the Bend command and select each corner point to create the bend so the sweep is smooth at the corners.
    6. Exit 3D sketch, and create a 2D sketch bases on XZ plane, and create a circle with its center on origin.
    7. Exit 2D sketch, and create a sweep feature with the circle as profile and the 3D sketch lines as path.
    Hope  this helps.
    Rocky Zhang
    Inventor API
    Manufacturing Solutions
    Curtis_Waguespack
    Re: Square helix??
    12-20-2012 07:48 PM in reply to: blmckenzi3
    Hi blmckenzi3,
    There are two example models you can find attached at this link:
    http://forums.autodesk.com/t5/Autodesk-Inventor/Making-a-rectangular-spring/m-p/3441447
    I hope this helps.
    Curtis
      solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
    Active Member
    Re: Square helix??
    12-21-2012 05:10 AM in reply to: yuhanzhang
    that excel file didnt work i got to the insert points commad and selected the excel file chose the create lines option hit open and nothing happened
    Active Member
    Re: Square helix??
    12-21-2012 05:33 AM in reply to: Curtis_Waguespack
    how do you make things translucent? sorry im kinda new at this
    Curtis_Waguespack
    Re: Square helix??
    12-21-2012 07:23 AM in reply to: blmckenzi3
    Hi blmckenzi3,
    You can do this by extruding a profile as a surface (rather than a solid).
    You might use the End of Part marker in the examples at the link to examine how the features were created one at a time.
    This is often a good way to learn a new technique. Post back if you have more questions and I'm sure someone will help.
    I hope this helps.
    Curtis
    Curtis_Waguespack
    Re: Square helix??
    12-21-2012 07:32 AM in reply to: Curtis_Waguespack
    Hi blmckenzi3,
    You might also see JDMather's knot tutorial for more on the general technique:
    http://home.pct.edu/~jmather/content/DSG322/Inventor%20Tutorials/Inventor%2011%20Tutorial%207.pdf
    I hope this helps.
    Curtis
    Active Member
    Re: Square helix??
    12-21-2012 11:50 AM in reply to: Curtis_Waguespack
    Thanks everyone! oh man ive been trying to do this for almost two weeks now :smileytongue:
