• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Splitting the horizontal spline
    199 Views, 7 Replies
    10-25-2012 06:09 AM
    I have followed every direction in the wikihelp spline and surfaces portion when creating the mouse but, for some reason, every time I try to split the horizontal section I get a message saying "The attempted operation did not successfully complete due to unforeseen problems. Try with different options or inputs." But when I go to split the vertical spline it splits just fine. What can I do to fix this? Thank you.
    Please use plain text.
    Re: Splitting the horizontal spline
    10-25-2012 06:50 AM in reply to: T.pot
    Attach your ipt file here.
    10-25-2012 10:49 AM in reply to: JDMather
    Mouse Spline file. I am not the only one that this has happened to.
    10-25-2012 11:09 AM in reply to: T.pot
    Extend the edge of the surface.
    It must completely cut the solid.
    Also, Sketches 4,6 & 8 are not fully constrained.  Add construction line from projected orgin to midpoint of splines.
    Can you post the url to the wiki page so that I can submit suggested clarifications.
    10-25-2012 11:26 AM in reply to: JDMather
    10-25-2012 11:40 AM in reply to: T.pot
    You put a link to your hard drive.
    I was execting an internet url to the on-line wiki.
    Well I'll see if I can find the page.
    http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/0127-Inventor127/0514-Splines_5...
    http://wikihelp.autodesk.com/User:drafts/505206
    10-26-2012 07:38 AM in reply to: JDMather
    The top URL that you sent me is basically the same thing.
    10-26-2012 10:00 AM in reply to: T.pot
    It should be exactly the same thing - I posted the url here for others that might come across this thread in a search since you posted a path to your C drive that we are not likely to have access to.
    I then posted a correction to the page, but I guess they didn't like my suggestion.
