• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Inventor
    Active Member
    Split Solid Error
    210 Views, 4 Replies
    09-19-2012 09:30 AM
    I'm trying to split a single solid body into 2 solid bodies. The problem is that the body I'm trying to split consists of two separate pieces. I can split a body when it is a single piece no problem, but I'm having the problem when the two pieces are not joined at all.
    When I try and split it on the origin plane it gives this error:
    "Creating parting line failed. Could not build this Split"
    When I try and split it on a work plane lying on one of the pieces it gives this error:
    "Creating parting line failed. Modeling failure in ASM. Redefine inputs."
    Or, another variation on this erorr:
    "Creating parting line failed. Split feature could not create two bodies. Change the Split Tool so that split feature can create two bodies."
    Is this possible to do?
    Please use plain text.
    Re: Split Solid Error
    09-19-2012 10:01 AM in reply to: __spidey_
    That would be two features.
    One Extrusion, one Split if it worked.
    Multi-body solids use two extrusions New Solid.
    Inventor Professional 2014 Edu 64-bit
    09-19-2012 11:16 AM in reply to: JDMather
    I see you are using 2010 - so your screen will look different than mine, but
    create first extrusion of only one box.
    Make sketch visible
    Create second extrusion and click the New Solid icon below join, cut, intersect
    or
    Mirror the original box and select New Solid.
    Active Member
    09-19-2012 11:19 AM in reply to: JDMather
    Thanks. Yes, that makes sense. For the actual part I'm working with, I need to rethink my workflow so that I use multiple extrusions using the new solids command instead of making the entire part, then trying to split it after.
    09-19-2012 11:24 AM in reply to: __spidey_
    I started to type up a work-around, but then deleted it.
    As Mike Holmes would say, "Just do it right from the start."
